Image correction
thire
Image correction
Post by thire »
It would be cool to have an option to do some auto-correction of images (brightness, contrast, gamma, ...). Are there some algorithms to estimate "good" values?
Re: image corretion
thire wrote:It would be cool to have an option to do some auto-correction of images (brightness, contrast, gamma, ...). Are there some algorithms to estimate "good" values?
You have auto levels and auto contrast
thire
Post by thire »
oh, yes, I see. In the menu. Sorry.
If there was an "auto"-button in the adjust->brightness... dialog it could be helpful.
sorry for my noise. :mrgreen:
th
geometra
how
Post by geometra »
Hi Pierre:
Can you explain how do you apply auto levels transformation?
I know how Photoshop does it because it is explained at its help. They cut the histogram at the tails by 0.5% of the values previous to the expansion. Are you making any of this? It is important to me to know if I will loos some values if I apply auto-levels and how many.
Congratulations for your work!
Re: how
geometra wrote:Hi Pierre:
Yes i cut histogram too
