Yakano
Post by Yakano »
Hi
How can I select transparent color of an image when saving it as file .gif,?
Thanks
Re: Save as transparent.GIF
Yakano wrote: How can I select transparent color of an image when saving it as file .gif,?
You can set the transparent index in option/Write/Gif, or use Edit/Edit colormap to set the transparent color.
Post by Guest »
OK, thanks for your help
Other question:
Can I transform a color into transparent usning an average?
In exmaple FFFFFF ± 10% will transform colors near to white in white and then white into transparent
Some hope? thanks
Anonymous wrote:OK, thanks for your help
Other question:
Some hope? thanks
No you can't
A good idea, though---
:arrow: Pierre
:) Hello Pierre !
Guest wrote
…In example FFFFFF ± 10% will transform colors near to white in white and then white into transparent
- I think this is a very good idea, because currently when applying the transparency from the palette, the colours close of the stated "transparent" remain, and this leads to get undesirable bunches of pixels / artifacts which make a so ugly image the most times…
- It should be great to have such a function, IMHO.
:mrgreen: Kind regards,
Re: A good idea, though---
Such a function would be really useful. The function should be somthing like "Replace colour A +/-tolerance with colour B" .
Setting transparency to colour "B" should remain a second and separate step, though (we have this, already).
ouistiti
Post by ouistiti »
A good idea, really ! I support that proposal. Many times, I'm bound to decrease the colours amount by hand to avoid such issues, then the final picture is much less nice :(
Paul
1,77245385090552...
Yakano
Post by Yakano »
A good idea, really ! I support that proposal...
Such a function would be really useful...
I think this is a very good idea...
Really thanks to all users :mrgreen:
Go Pierre, we will give you thanks a lot :wink:
