[0.87] Slow viewing .CR2 files
eugene-r
Post by eugene-r »
Since version 0.87 sequential viewing CR2 files in a folder became very slow. I use PgDn to going on next file, sometimes PgUp to return to previous. Version 0.87 switch to next/previous file very slow, even became unresponsible on fast PgDn-PgDn-PgDn-PgUp-PgUp-PgUp sequence.
Returned to version 0.86 - it works fast.
I have same issue on all my PCs - two desktop and laptop. All running Ubuntu 16.04 LTS with current updates.
For viewing camera raw files embedded preview is used.
Re: [0.87] Slow viewing .CR2 files
O.k., thank you, I can also reproduce the problem. See issue 1314 for current status and some details. I'll post here once the problem has been fixed.
This problem is supposed to be fixed in XnView MP 0.88. Please check and confirm the bug fix here.
eugene-r
Post by eugene-r »
xnview wrote:Please check and confirm the bug fix here.
Looks like it works perfectly now! Thanks!
