How much of what this program does with EXIF can XnView do?
What about XnView Deluxe?
Exif2htm
Acritum Software
Shareware ($19.95)
XnView/XnView Deluxe vs Exif2htm (Acritum)
Windows 11 (64-bit), Android 12, XnViewMP 1.5.0, XnResize 1.10, XnShell 4.16
** XnView ROCKS **
** XnView ROCKS **
Re: XnView/XnView Deluxe vs Exif2htm (Acritum)
I just had a look at EXIF2htm to see what it does. Bascially, you can create webpages containing images and all their EXIF info.SeaMaiden wrote:How much of what this program does with EXIF can XnView do?
Exif2htm
Acritum Software
Shareware ($19.95)
I had a look at XnView to see what it can do. Currently, there are no placeholders for EXIF information which you could use in the HTML template. The only way to include EXIF information is the information field (Show information). This means that people could create a webpage with EXIF info, but all the EXIF info would have the same formatting.
Currently the web templates define the design and layout, not the contents: The field "Show information" is not part of the web template, so you there's no way to provide a web template for people who want to have all the EXIF info.
I haven't tried in XnView DeLuxe, but I think it will be basically the same.
Greetings to the U.S.,
Helmut
