Fit img to desktop, all: Left aligned?
klaus2
Post by klaus2 »
Is it possible for "fit image to desktop,all" to have the viewer window left aligned instead of centered;
if not: are there any other votes to allow that by option?
Re: Fit img to desktop, all: Left aligned?
klaus2 wrote:Is it possible for "fit image to desktop,all" to have the viewer window left aligned instead of centered;
Currently not possible.
klaus2
Post by klaus2 »
Hi Pierre,
then i would like to request it :-)
(reaon is: better usage of the desktop space when browsing with the viewer -
you can rely that mostly (with smaller images) the right part of the screen will stay free other operations, whereas the centered mode more ore less blocks the whole screen)
Basically accepted?
Kind Regards.
klaus2
klaus2
Post by klaus2 »
hi ..
the proposal is not good?
many thanks!
klaus2
klaus2 wrote:hi ..
No, i add it to my TODO list :-)
klaus2
Post by klaus2 »
Hi Pierre,
many thanks, again!
To have presentation flexibility like that, together with the speed issue
(cancel paint if next pic requested), for me xnview finally will be the best and only image browser ..
Please continue supporting such very 'basic' functionality ..
best wishes!
klaus2
klaus2
Post by klaus2 »
Hello Pierre,
is it possible to have some vague expectation when (which release) this item
possibly might be integrated?
Purpose is that the user is more free to decide where the viewer window is placed,
alternatively to the centered mode which costs much screen space (caseof small images).
Many thanks again,
klaus2
klaus2 wrote:Hello Pierre,
Currently i don't know, i work on 1.82 and can tell you that this feature will be not in it, too many requests :-)
klaus2
Post by klaus2 »
Hello Pierre,
i understand well.
Does it make sense to wait?
Good luck with the 1.82
klaus 2
Post by Guest »
was this feature ever released? it will not left or right justify and only centers for me if I have "fit window to desktop, large only" set. running 1.82.4.
Post by Guest »
anyone? bueller?
Anonymous wrote:anyone? bueller?
I've added this request in my TODO list :-)
Post by Guest »
you the man, thanks!! ideally the window should remember its position anwhere on screen, not just left or right justified.
