Aspect ratio value
sprayer
Aspect ratio value
Post by sprayer »
Can i suggest to change behavior for aspect ratio stat
when image is vertical the stats would be less then <1
for example horizontal image 800/600px = 1.33
vertical 600/800 = should be 0.75
it easy to calculate right aspect in other software like 3ds max etc
Thanks
Re: Aspect ratio value
sorry but i don't understand your request
sprayer
Post by sprayer »
xnview wrote: Fri Nov 30, 2018 9:05 am sorry but i don't understand your request
Hi Pierre,
here an example in xnview and in 3ds max aspect ratio how it shows the same resolution of image
http://imagizer.imageshack.com/img924/7590/rrdOoI.jpg
http://imagizer.imageshack.com/img921/5837/5zyo1R.jpg
i want it to be like in 3ds max 0.75
right, i don't remember why it was like that but See issue for current status and some details.
sprayer
Post by sprayer »
Thank you Pierre!
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
sprayer
Post by sprayer »
xnview wrote: Thu Jan 31, 2019 1:50 pm This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
Hi Pierre,
Still the same behavior
Left image should have 0.661 aspect ratio
you need to edit xnview.ini
[General]
positiveRatio=1
sprayer
Post by sprayer »
Can't find in ini file
[General]
Adding this settings do not change anything
In [%General] please use positiveRatio=false
sprayer
Post by sprayer »
Now it works, thank you.
Are you planning to implement this option in GUI?
sprayer wrote: Fri Feb 01, 2019 7:59 am Now it works, thank you.
perhaps in a future version
