Rotate dialog: Drop down list for standard angles.
In the dialog "Rotate" (Image > Rotate > Custom...) there's an edittext which allows for entering arbitrary rotation angles. I think that changing it to a drop down list and adding angles like 0, 45, 90, 180, and 270 would be good. Or the recently used angles could be stored in the drop down list.
XnView 1.82 alpha
Re: Rotate dialog: Drop down list for standard angles.
helmut wrote:In the dialog "Rotate" (Image > Rotate > Custom...) there's an edittext which allows for entering arbitrary rotation angles. I think that changing it to a drop down list and adding angles like 0, 45, 90, 180, and 270 would be good. Or the recently used angles could be stored in the drop down list.
Not sure, often we need to enter a custom angle
Post by Guest »
I support Helmut's list of recent used angles, which will include all standard angles after some time of using it.
Perhaps it should be limited to i.e. 8 entries.
@Pierre: Do we really *often* need custom angles? :mrgreen:
Lesmo16
Post by Lesmo16 »
:? It seems, that something's wrong with the forum software ...
Previewing my above post worked fine, submitting immediately after preview logged me out!
Everyone who believes in telekinesis, raise my hand!
