Suggestion for Zoom Selection
Lee James
Post by Lee James »
When you're dragging a selection to zoom, the selected area has grid lines and squares in the corner. I find these ugly and would like to be able to turn them off.
Here's an image I made to demonstrate:
It would also be nice if you could make the background darker.
Re: Suggestion for Zoom Selection
you can change in xnview.ini
selectionGrid=0
+1 Add option in Settings > View -- Show grid lines in selection ... :wink:
Lee James
Post by Lee James »
Thanks Pierre! Looking forward to v0.93 :)
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
