Crashes when renaming, creating folders or favorites
I have crashes when creating and renaming real folders and renaming favorites (not when creating favorites)
This happens 20% percent of times. When opening again XNview normally I can do the same operation without crashing.
I have sent a report file automatically generated and using my user email with the auto report in program system.
I have tried to optimize etc the database with no results.
Windows 10 64, last version of XnView.
I typically work with several instances of Xnview MP open, but not sure if that is relevant at all. When one crashes the other are Ok.
Re: Crashes when renaming, creating folders or favorites
Well, then in this case adding folder creating and renaming, something I do a lot more often than with favorites.
do you have often crashs "when creating and renaming real folders"? Which OS? do you have sent a dump with crash dialog?
I have responses for all in my first post of this bug
Sorry, could you describe more the step to reproduce?
Do you use catalog? Do you rename in thumbnail view? Are you in thumbnails view?
I use catalogue
I rename in thumbnail view and I'm in thumbnail view. But I typically rename folders and create folders. I don't remember this problem renaming files (but simply because I do it rarely.
There is
The steps are in Thumbnail mode:
Right click over the tree folder window over a folder and click new folder
OR
Right click over the tree folder window over a folder and click rename
Crashes in both the 20% of times
I don't do this normally over the thumbnails window but in the tree folders window, even I'm in the thumbnail mode.
I need to point I avoid systematically renaming the same folder that shows the thumbnails as this normally will return with the error "can't rename". I guess the program struggles to rename the same folder displaying thumbnails but this is a different (and very old) bug.
There is
OR
i've tried to create/rename subfolder in tree view, but no crash. Perhaps you can send me your .ini?
And perhaps a screen video? It seems that you have the crash too on windows 10
I have it included as attachment. I have simply deleted the last folders visited section.
Yes, windows 10
Yes, windows 10
- Attachments
- xnview.zip
- (7.64 KiB) Downloaded 227 times
with your .ini, i can reproduce this issue , i send you a PM
This problem is supposed to be fixed in XnView MP 0.93. Please check and confirm the bug fix here.
The impression I have based in the test I have done is that it is OK now
