I tried the bug fix of the long annoying problem of the print custom size with 9.3: unfortunately the bugfix is still not found at least under Linux mint 18.
The page size setting still is ignored, for example I set the size to A3, it will always print A4. It ist the same with "page setup" as in "Printer properties". The setting portrait/landscape is ok, it only concerns the page size.
In addition, a very dear wish of mine is to exert influence of the order of pictures for prints: often i want to print a collection of pictures on one sheet but I need to set a special order manually. The simplest way were to use the selection order with the mouse, for example if I "contrl mouseclick" the 3rd, 1st, 2nd picture from the folder view, it should print in this order on one sheet of paper.
norand
p.s. thank you for one of the best programs I know!
0.93: print custom size still broken in linux mint / print order
norand
