Process filelist
Hacker
Process filelist
Post by Hacker »
Hi Pierre,
Could you please add an option for XnView to read filenames from a filelist? A filelist would look like this:
c:\long name\file.jpg
c:\long name\file2.jpg
d:\another dir\another file.bmp
A parameter like "-l <filelist.txt>" or "-list <filelist.txt>" could be used.
TIA
Roman
Lesmo16
Re: Process filelist
Post by Lesmo16 »
I highly support this request.
Hacker wrote:A parameter like "-l <filelist.txt>" or "-list <filelist.txt>" could be used.
And the parameter "-l" would be available, so Roman is well prepared - as usual! :)
Everyone who believes in telekinesis, raise my hand!
This is really a good and very important suggestion, Roman. Currently, scripting is a bit hard since file lists cannot be passed easily. Adding this will make nconvert much more flexible and mighty and scripts simpler.
I think the mid- / longterm consequence is having both an option for including a file list and another one for including a process list. The process list will be a plain text file containing processes which should all be applied on the image files. The process list will make things more flexible and make sure that files do not have to be saved and opened over and over again for applying several processes. This should improve performance and improve quality of the results since nconvert can apply all processes in one step without intermediate saving. (Currently, if you use a lossy image format quality will decrease whenever applying a process and saving).
Hacker wrote:Hi Pierre,
Yes, good feature, i'll add it
Post by Guest »
Any news on this?
As far as I can tell (looking at -help), there is still no option for this.
Anonymous wrote:Any news on this?
I'll add this option in next release...
Post by Guest »
xnview wrote:I'll add this option in next release...
Great! Thanks a lot
Hacker
Post by Hacker »
After a long time - thank you! :)
However, when I execute
nconvert.exe -l listfile.txt
all files are processed correctly but at the end I get an error message saying:
Error: Don't know how to read this picture (listfile.txt)
Any ideas?
TIA
Roman
oops66
Post by oops66 »
A parameter like "-l <filelist>" or "-list <filelist>" could be used.
TIA
Roman
You already can do this kind of thing in XnView by slide-file.sld
And you have juste to put you file liste:
At the end of this .sld file.
(Timer = 0 or 2 or more)
--------- slide-file.sld -------------
# Slide Show Sequence
Timer = 2.000000
Loop = 0
FullScreen = 1
TitleBar = 1
Fit = 0
StrechVideo = 0
High = 1
CenterWindow = 1
ReadErrors = 1
RandomOrder = 0
ShowText = 0
Text = <Directory><Filename> <Width>x<Height>||<Date>||ISO <ISO> - F<F> - S <Exposure>||Focale <Focal> <Focal>||<Make> <Model> <Flash> <Flash>||
BackgroundColor = 0
FontName = "Courier"
FontBold = 0
FontItalic = 0
FontHeight = -13
TextColor = ffffff
TextPosition = 6
Effect = 2
EffectMask = 16777215
"c:\long name\file.jpg"
"c:\long name\file2.jpg"
"d:\another dir\another file.bmp"
Hacker
Post by Hacker »
Well, in the original post I meant NConvert of course. ;)
Roman
oops66
Post by oops66 »
Hacker wrote:Well, in the original post I meant NConvert of course. ;)
Roman
Yes, but maybe Nconvert can generate and launch this kind of file With a futur parameter -slide_list <filelist>?
It's only a suggestion !
Hacker wrote: all files are processed correctly but at the end I get an error message saying:
Any ideas?
Ok, i'll check...
Hacker
Post by Hacker »
Not fixed in XnView 1.91.6.
Roman
Hacker
Post by Hacker »
Fixed in XnView 1.92. :)
Thanks a lot!
Roman
