0.93.1: In Fullscreen mode Auto image size setting does not reset when current image is moved
jaybee604
Post by jaybee604 »
XnView: MP 0.93.1 - 64-bit
OS: Windows 10 - 64-bit
Effect: In Fullscreen mode the current auto image size does not reset when moving the current image
When using XnView in Fullscreen mode to view new images in a folder I either delete or move the current displayed picture. The auto image size usually is set to "fit image to large only". When deleting a image the zoom level is reset as expected but when moving the image to another folder the auto image size setting does not reset for the next image which is displayed. After switching to window and back to fullscreen mode the correct setting is active again.
1. In the XNView settings (View+Fullscreen tabs) set auto image size to "fit image to window, to large only" and check the "reset auto image site with next/previous file"
1. Browse a folder with at least two image files which have a smaller resolution than the desktop (JPEG format).
2. Select first image file.
3. Open fullscreen (view) using F11 key.
5. While the first image is displayed change the auto image size to "no fit" so the image is enlarged to fit the desktop size.
4. Press "Alt-M" or the assigned key for "cmd_moveFileTo" to move the current image to another folder
Actual behaviour (bug): The next image is displayed with the "no fit" zoom level still in effect.
Expected behaviour: The auto image size should be reset also after a image has been moved
Re: 0.93.1: In Fullscreen mode Auto image size setting does not reset when current image is moved
like when you go to next/previous file??
jaybee604
Post by jaybee604 »
Yes this is working fine when going to next/previous files and also when copying / deleting the current pimage. in all these cases the auto image size is reset. But when moving the image the auto image size is not reset for the next image which is displayed after the "Move-to" dialoge was answered.
yes i can reproduce but only if cache is enabled. So another bug, if cache is disabled, 'reset auto image size' doesn't work
jaybee604
Post by jaybee604 »
Hi, do you know when this bug is going to be fixed? This still is happening. I wonder if I am the only one who complains about this? No other users zooming and moving images? :)
