Checkbox for Watermark direct in print dialog
sunhill
Post by sunhill »
i would like to make the suggestion, that you place the check box for the watermark directly into the print dialog instead of the window of the watermark options.
I am certain, this will avoid a lot of wrong printings. :wink:
If it is possible, it would be great, if you could add the selected watermark to the preview (maybe as an overlay?) in the print-dialog too.
Thank you in advance.
SunHill
Re: Checkbox for Watermark direct in print dialog
sunhill wrote:Hello,
Yes, i must changed the print dialog in a future version.
