A “Saved as…” file has a unknown format !
:arrow: Pierre
- This thread is related to this message.
- Please, test the following, the Option "Change the name after Save as…" being ticked :
2. Ask for "Save as –> fileX.JPG in the same directory than the original file.
4. Press Ctrl+R to reopen the “displayed” file : you get an error message telling that the fileX.jpg has a unknown format (in French, in English the message is else)
:| I guess there are :bug: :bug: somewhere, since :
a) The programme doesn't refresh the display automatically as soon as you have converted the format by saving it as…, although the new name is shown. To be sure of this, simply look at the tool-bar : despite a JPG file-name is shown, the JPEG … button stays disabled.
b) Then the "Reopen" command might acts simply, and should not lead to get an error message in the case.
- The way in which XnView might find out the new path for the "saved as…" file, whether you saved it in any else dir. than the source-file one is your "cooking" :P
:mrgreen: KR
ouistiti
Post by ouistiti »
2 Clo
I confirm : the displayed file and the filename in the title-bar don't match.
- Right, watching the JPG button allows to know that this is not a JPG on the screen.
- I agree, the program might reload / refresh the file to the saved one...
Paul
1,77245385090552...
Re: A “Saved as…” file has a unknown format !
Clo wrote:- Please, test the following, the Option "Change the name after Save as…" being ticked :
4. Press Ctrl+R to reopen the “displayed” file : you get an error message telling that the fileX.jpg has an unknown format (in French, in English the message is else)
Right a bug
Right a bug
Yes, a severe one since people might loose their image (just happened to me). I've just added this one to the lits of must fixes.
helmut wrote:Yes, a severe one since people might loose their image (just happened to me). I've just added this one to the lits of must fixes.
Loosing image data is not possible, here, but the error message was irritating.
This is solved in XnView 1.90.
-> Closed.
