batch frame making ... size delta
marsue
Post by marsue »
another topic for another issue, ... better for search engine !
So here are the settings:
I want to expand the canvas, say, by 1px on every side, and then by 5px on everyside. This is to make a very cool-looking frame.
At the moment i can only resize the canvas to a fixed px size :-( then I end up with a little 1x1 px, not what I want. and if I use the % I cannot control how many px are added if not all my pictures are not the same size (which is often the case, as I own different cameras ;-) ).
So could it be posible to have the "relative" enlarge canvas (as in photoshop) , so if center is chosen -canvas +2 +3 will add 2px on each horizontal sides, and 3 pix on each vertival sides ...
this would be definetly great ! for sure ...
Marsue
Re: batch frame making ... size delta
marsue wrote:Hello,
Ok, i'll add this feature
marsue wrote:... this would be definetly great ! for sure ...
Good and useful suggestions, Marsue. :-) I second this.
marsue
Post by marsue »
thanks a lot for your reactivity !
I'm looking forward to the new version.
marsue
Post by marsue »
Little hello,
has this been implemented ?
regards,
Marsue
marsue wrote:Little hello,
Not yet, sorry
Cinemaizer
Post by Cinemaizer »
Hello Pierre!
I have a need for this feature also... the frame around converted picture with certain pixels by horizontal and vertical side. I think it must be implemented in -canvas, how people are recommended above.
Cinemaizer wrote:Hello Pierre!
You have -delta #x #y
Cinemaizer
Thanks Pierre! I've known this feature but previously i've not known how it works:)
