More direct access to 'Zoom 100%', Additional separator
Two minor things:
I think "Zoom 100%" is an often used function. Currently, the menu item to set zoom to 100% (=no zooming) is buried in menu "View > Zoom > 100%". I propose a bit more direct access by providing a menu item "View > Zoom 100%".
This menu item will be double, then, but I think that's o.k. Sure enough, this change should be applied for all menus, including context menus (preview, view mode, fullscreen mode, ...).
A too minor request to start a new topic and even related:
In the context menus for preview, view mode, and fullscreen mode, the menu items for Zooming should be separated from the menu items for navigation using a separator. This will make the context menu clearer.
Post by Guest »
There should also be a quick button for "fit window" or "fit desktop" zoom. Now if the image is fitted to window and you zoom it in or out, you can't go back to "fit"
