Logarithmic LUT do not appear
Chuclkles
Post by Chuclkles »
I have spend most of the day trying to figure out how to get a Logarithmic lut working....
I have found some on this forum but they just do not appear. I have put then in the AddOn/clut folder. Can somebody help??
Re: cluts
Welcome to the forum, Chuclkles.
Are we talking about XnView Classic (v2.49.2) or XnView MP (v0.96.1)?
Classic:
  • ImageMapLogarithmic Lut
  • ToolsBatch Processing…TransformationsMapLogarithmic Lut
  • %ProgramFiles(x86)%\XnView\Lut\*.lut
Chuclkles
Re: cluts
Post by Chuclkles »
In am using the XnView MP (v0.96.1)...
Chuclkles
Re: cluts
Post by Chuclkles »
I have installed XnView MP on both a PC and Mac. On the mac I have found some luts in the AddOn directory...none on the PC but I copied them to the AddOn directory. The problem is that I keep getting "no settings"...
Screenshot 2020-04-21 at 08.51.02.png (15 KiB) Viewed 20520 times
Re: cluts
'Logarithmic lut' has no settings, it apply it
clut folder is used by 'Image>Film simulation'
Chuclkles
Re: cluts
Post by Chuclkles »
Thank you Pierre. I'm sorry if I do not understand...but in the clut folder there are many luts. How do I select one or another?'
Re: cluts
no need to select one, go to 'Film simulation' tools
Chuclkles
Re: cluts
Post by Chuclkles »
THANK YOU!! Finally I see it working.
How can I get it to work for Batch Converting?
Re: cluts
Chuclkles wrote: Tue Apr 21, 2020 12:45 pm How can I get it to work for Batch Converting?
currently not supported
Chuclkles
Re: cluts
Post by Chuclkles »
Ah...ok!! Any chance that feaure will be add soon??
Re: cluts
Chuclkles wrote: Tue Apr 21, 2020 1:22 pm Ah...ok!! Any chance that feaure will be add soon??
yes i'll add it
Chuclkles
Re: cluts
Post by Chuclkles »
Thank you very much for your help and patience :D :D
marcelvidal83
Re: cluts
Post by marcelvidal83 »
xnview wrote: Tue Apr 21, 2020 9:17 am 'Logarithmic lut' has no settings, it apply it
Hi I have installed XnView MP Windows Version 0.98.1 64bits on my new Win 10, previously I was using the Film Simulation option on XnView on my Mac.
On my PC, when I click Image> Film Simulation I get a Film Simulation dialogue box with an empty preset list ... Am I doing something wrong? With the version on my Mac there was a whole bunch of Film Simulations already pre-loaded. Do I need to download presets from somewhere? thanks :)
Re: cluts
marcelvidal83 wrote: Sat Feb 20, 2021 5:07 pm
No you should have all default presets???
marcelvidal83
Re: cluts
xnview wrote: Mon Feb 22, 2021 10:29 am
Deinstalled and reinstalled as adminitrator- still no change, do these files exist anywhere online that I can install them manually?
