0.96.1: CSS styles not working
Irrawaddy
Post by Irrawaddy »
XnView MP 0.96.1 64-bit on Windows 10 1903.
Version 0.96.1 does not render CSS styles at all on full screen. CSS styles on 0.95 were working OK.
0.95 displayed CSS styles properly:
0.96.1 does not use CSS styles at all:
I'm using the following string for full screen info:
<span style="background-color: rgb(50,50,50);">{Filename}
 &nbsp; &nbsp; <span style="font-weight: bold;">{Folder name} &nbsp; &nbsp;</span><span style="color: Gray; background-color: rgb(50,50,50);"> {File Index}
 &nbsp; &nbsp; <span style="color: White">{Modified Date [Y]}</span>{Modified Date [-m-d H:M]}
 &nbsp; &nbsp; {Width} × {Height} @ {Ratio} ({MPixels} MP) • <span style="color: White">{Size KB} </span>kB • {File Type}
</span>
Re: 0.96.1: CSS styles not working
See issue for current status and some details. I'll post here once the problem has been fixed.
This problem is supposed to be fixed in XnView MP 0.96.2. Please check and confirm the bug fix here.
Irrawaddy
Post by Irrawaddy »
0.96.2 fixes this bug. All is OK now.
