XnConvert [1.82+]: Alpha channel problems
crazydaz
Post by crazydaz »
On 1.80 and earlier - "Change Color Depth 32bits Alpha 255" used to add pure white Alpha Channel.
On 1.82+ it does nothing.
If your image has alpha, and you simply convert it to 24bits it will look cutout.
In the past, it was possible to workaround it, by simply getting rid of Alpha Channel:
Converting it into full white 255, and then flattening it with 24 bits. Receiving a nice full image.
Now it's broken.
On 1.80:
Change Color Depth: 32 bits Alpha 255
Resize: 3k
ICC Convert
Canvas Resize: 3k x 3k , Alpha 255, Keep Ratio
Change Color Depth: 24 bits
Produces:
On 1.85:
Same settings produce:
crazydaz
Re: XnConvert [1.82+]: Alpha channel problems
Post by crazydaz »
Change Color Depth is broken in 1.85.1.
But for my intended use, I managed to delete Alpha Channel by:
1. Create a full white image in any image editor and save it as GIF in XnConvert Mask directory:
On Mac: /Users/XXXXX/Desktop/XnConvert.app/Contents/Resources/AddOn/Masks/white.gif
2. In XnConvert Add action: "Add mask"
3. Navigate to the image you have created in the previous step:
e.g.: /Users/XXXXX/Desktop/XnConvert.app/Contents/Resources/AddOn/Masks/white.gif
2. Check "Use mask as Alpha"
4. Add "Change color depth"
5. Select "24 bits"
How do I invert the alpha channel of an image?
could you send me the original file?
crazydaz
Post by crazydaz »
xnview wrote: Mon Jul 20, 2020 1:20 pm could you send me the original file?
https://we.tl/t-ZrxYx0NkW0
I've included 3 files:
  • 1x Original
  • 1x generated with XnConvert 1.80:
    Resize: 3k
    ICC Convert
  • 1x generated with the same settings on XnConvert 1.85.1
    Resize: 3k
    ICC Convert
crazydaz wrote: Tue Jul 28, 2020 1:20 pm
Sorry but the link has expired, could you post it again?
crazydaz
Post by crazydaz »
Sorry for the delay.
https://we.tl/t-qaWu9DsCMY
All exported with the same settings:
Resize: 3k
ICC Convert
This problem is supposed to be fixed in XnView MP 0.98.0. Please check and confirm the bug fix here.
crazydaz
Post by crazydaz »
xnview wrote: Mon Dec 14, 2020 2:45 pm This problem is supposed to be fixed in XnView MP 0.98.0. Please check and confirm the bug fix here.
Sorry for the late reply.
Can confirm it is fixed in XnConvert 1.90! Many thanks!
