0.97.1: Ampersand in file name displays in tab as two spaces
disillusioned
Post by disillusioned »
XnView: MP 0.97.1 - 64 bit
OS: Windows 10 64bit
When an image file name contains an ampersand (&), the file name displayed in the tab has two spaces instead of the ampersand. Additionally, after the Alt key is pressed, the ampersand is now displayed as a space followed by an underscore.
Effect: Uncertainty about the file name of the image being displayed.
1. Rename an image file to "a & b & c.jpg"
2. Open the file in a tab
Actual behaviour (bug): File name displays as "a b c.jpg" :bug:
3. Press the Alt key
Actual behaviour (bug): File name displays as "a _b _c.jpg" :bug:
Expected behaviour: File name is displayed as "a & b & c" in each case.
fireattack
Re: 0.97.1: Ampersand in file name displays in tab as two spaces
Post by fireattack »
This is just the default WIndows UI behavior - &X (or any character, in your case, the space next to ampersand) will consider X as the shortcut of this UI element. and when you press alt it shows underscore to highlight it so you can press to activate it. Like &File in menu.
I agree it should be changed/disabled in tabs though.
This problem is supposed to be fixed in XnView MP 0.98.1. Please check and confirm the bug fix here.
disillusioned
Pierre, thank you so much for your response and for your work on this. Unfortunately, this issue still occurs in 0.98.1.
disillusioned wrote: Sun Feb 07, 2021 12:35 am Pierre, thank you so much for your response and for your work on this. Unfortunately, this issue still occurs in 0.98.1.
sorry but i can't reproduce anymore
disillusioned
Wow, this is really interesting. When 0.98.1 came out, it appeared to me that the issue had been resolved. Then, a couple days ago it reappeared and I reported it here. When you replied that you couldn't reproduce it, I tried again and couldn't reproduce it.
Now, it has reappeared again, in two different flavors--a space followed by an ampersand followed by a space sometimes displays as a space followed by an underscore:
space underscore.jpg (12.47 KiB) Viewed 2947 times
and sometimes as one space (or is it two?):
two spaces.jpg (12.79 KiB) Viewed 2947 times
I don't recall the sequence of events that led to each outcome--switching between viewing from the file system vs. the image browser, switching between fullscreen and viewer, etc. I might have time this week to try to determine and document what leads to each.
Thanks as always for your work on XnView!
This problem is supposed to be fixed in XnView MP 0.98.2. Please check and confirm the bug fix here.
disillusioned
This appears to have been fixed. Thanks so much!
