b1: Old mode switching bug still there
Danny
Post by Danny »
Bug has been there as long as i can remember. Follow these steps:
1. Browser maximized.
2. Doubleclick = viewer
3. Auto image size = fit image to desktop, large only
4. Remember different window position
5. Use different size/position for browser & view
Now doubleclick on a picture bigger than your desktop resolution from the broser mode.
-> the window will resize first, then the picture is being resized -> slow and annoying
Then doubleclick the picture again.
-> The browser will have the same size as the picture you've just viewed instead of still being maximized
Cheers
Danny
XnView 1.82 <x>
marsh
Post by marsh »
I might be reporting the same thing that you are. I'm not sure:
Old Bug: Maximizing & unmaximizing browser (with square windows icon) can cause previous browser dimensions to be forgotten and then browser will inherit previous viewer size.
Re: Old mode switching bug still there
Danny wrote:Bug has been there as long as i can remember. Follow these steps:
Ok, there si some problem when you are in maximized mode...
Danny
Post by Danny »
Now doubleclick on a picture bigger than your desktop resolution from the browser mode.
Ok, there is some problem when you are in maximized mode...
Difficult to fix or what's the crux of the matter?
Yes currently difficult to fix it
Danny
Post by Danny »
xnview wrote:Yes currently difficult to fix it
I see. :|
It's a seriously frustrating bug though.
Well, i'm sure you'll give it your best. Good luck.
