Original images not deleted after batch operation
Konzertheld
Post by Konzertheld »
Hello there,
using XnView MP 0.98.0, I found that images are not deleted when requested so when using the batch operation mode.
- select some images
- open batch processing
- no operations, set folder, file name and file format / extension and activate "delete original files when done"
- confirm warning dialogue
- images are processed but originals are not deleted
- relative or absolute target folder path makes no difference
- multi CPU use yes or no makes no difference
Looks like a bug to me. I like to use this combination of settings to convert files to another format and move them in one process.
Cheers,
Christian
Re: Original images not deleted after batch operation
on Windows?
Konzertheld
Sorry, no, on Linux, Manjaro, to be more precise, using Gnome.
This problem is supposed to be fixed in XnView MP 0.98.1. Please check and confirm the bug fix here.
Konzertheld
Confirmed. Thank you!
