Change EXIF Date&Time
Dirk
Post by Dirk »
i'm missing this functions:
if digi cam have a wrong time, or you are travelling over a time zone and so on.... I want to correct the EXIF-picture-taken to the correct time &date.
The function/dialog should also looks like "Change timestamp"
Re: Change EXIF Date&Time
Dirk wrote:i'm missing this functions:
The function/dialog show also looks like "Change timestamp"
Ok, i'll add in a future version the feature to adjust EXIF date time
Dirk
very good
Post by Dirk »
Thank you - at the moment I'm working with 3 tools for images.
If this function is ready then I need only one tool ...and thats the great XnView!
:D
