"replace only if original value is empty" for Edit XMP...
herb
Post by herb »
Hello Pierre,
I am working on a Windows 10 system with version 0.98.2.
The dialog "Edit IPTC..." for multi-selection of files has the options:
- keep original value if new value is empty
- replace only if original value is empty.
But dialog "Edit XMP..." for multi-selection does only have
This dialog should be enhanced also with option
Thanks in advance
herb
Re: "replace only if original value is empty" for Edit XMP...
I've not kept these options for XMP because not sure that they are used??
herb
Post by herb »
Hello Pierre,
The IPTC organisation defines all IPTC-tags and it recommends the following:
- write/store IPTC-tags inside XMP
- and store them also in IPTC-IIM - but for legacy only.
So please implement "replace only if original value is empty" for Edit XMP...
Edit IPTC... and Edit XMP... should behave identically.
Thanks in advance
herb
