Webp export transparency
rotiya
Post by rotiya »
Am I missing some option? Because when I try to export a PNG to WebP, it loses its transparency.
using this tool with the same file, it retains transparency.
Re: Webp export transparency
i can't reproduce, with which file?
rotiya
Post by rotiya »
xnview wrote: Tue Jul 13, 2021 12:04 pm i can't reproduce, with which file?
This file:
https://imgur.com/a/B7J38rb
If you open it in xnview, the background is transparent, but if you try to export to webp, it's no longer transparent.
rotiya wrote: Tue Jul 13, 2021 12:56 pmThis file:
Palette-based PNGs with an alpha channel have to be converted to truecolor with alpha channel in order for transparency to be preserved during export:
  • ImageChange color depth…32 bits
rotiya
Post by rotiya »
xnview wrote: Thu Jul 15, 2021 8:05 am :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
Awesome!
Thank you.
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
xnview wrote: Thu Sep 16, 2021 12:20 pmThis problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
Fixed in XnView MP v0.99.0 64-bit :bugfixed:
