b1: edit iptc - write all selected
Anika
Post by Anika »
1. If I select many pictures and edit the iptc data with "write all selected" I get no information when the process is finished. If I click too early on the cancel button I get the message that XnView is in process. I would suggest to show the hourglass cursor while operating.
2. The caption "cancel" is a little confusing. Usually it is used if no changes should be applied. "Close" would be more neutral.
3. I it possible to add the ability to change the order of the IPTC keywords?
XnView 1.82 <x>
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
Re: b1: edit iptc - write all selected
Anika wrote:1. If I select many pictures and edit the iptc data with "write all selected" I get no information when the process is finished. If I click too early on the cancel button I get the message that XnView is in process. I would suggest to show the hourglass cursor while operating.
Ok
I'll add in my TODO list
Xyzzy
Post by Xyzzy »
It seems so far only changed Cancel to Close.
X.
Xyzzy
Post by Xyzzy »
OK, so in rc1 we have Close and hourglass.
There is still no possiblity to arrange keywords. Moving to New.
X.
Xyzzy wrote:OK, so in rc1 we have Close and hourglass.
Not for this release
