MP 0.99.1: Cannot delete file when entering full screen
ulysselio
Post by ulysselio »
Bug since XnView MP Windows, Version 0.98.4 64bits (May 28 2021)
In the same contex as Bug 2074: Info not showing on entering fullscreen. https://www.xnview.com/mantisbt/view.php?id=2074
When entering full screen, the file cannot be deleted. When I go to next or previous picture after entering full screen, file can be delete OK.
The following options in Settings are checked:
View > Info:
Always in fullscreen
View > Fullscreen > Fullscreen:
This used to work in MP 0.98.2 and previous versions
Thanks for your good work
Re: MP 0.99.1: Cannot delete file when entering full screen
is it Fullscreen from browser mode or edit mode?
ulysselio
Post by ulysselio »
> Fullscreen
i need to know if the fullscreen is from browser mode or edit mode?
ulysselio
Post by ulysselio »
fullscreen from browser mode
So, you are in browser, click F11 on a file, and press Del key?
Nothing happened?
ulysselio
Post by ulysselio »
Exactly.
to delete this file: next file and previous file: ok, i can delete
it works here, jpeg?
ulysselio
Post by ulysselio »
Yes, jpg
I send my xnview.ini
xnview.zip
(8.67 KiB) Downloaded 205 times
This problem is supposed to be fixed in XnView MP 0.99.4. Please check and confirm the bug fix here.
ulysselio
Post by ulysselio »
The problem was resolved.
Thank you for your excellent work
neunharpyi3
Post by neunharpyi3 »
Hi XnView Team,
I am using MacOS Monterey 12.0.1, updated to 0.99.4 but unfortunately, I still can not delete files in fullscreen yet.
Have a custom key which is my "#"
- re installed the app - no changes
- changed key-combination, no changes
any help?
neunharpyi3
xnview wrote: Thu Dec 02, 2021 11:57 am This problem is supposed to be fixed in XnView MP 0.99.4. Please check and confirm the bug fix here.
Hi XnView Team,
I am using MacOS Monterey 12.0.1, updated to 0.99.4 but unfortunately, I still can not delete files in fullscreen yet. (Neither Browser Fullscreen nor normal fullscreen)
any help?
neunharpyi3 wrote: Sun Dec 05, 2021 2:48 am I am using MacOS Monterey 12.0.1, updated to 0.99.4 but unfortunately, I still can not delete files in fullscreen yet. (Neither Browser Fullscreen nor normal fullscreen)
It's not the same bug, please create a new post
