0.99.1 Face tag regions displaying incorrectly [Mac]
Nicolas
Post by Nicolas »
XnView MP MacOSX 10.15.7
Version 0.99.1 64bits
When I browse pictures containing face tag regions (in full screen or in "open" mode, using arrow keys to change pictures), they are usually displayed correctly at first but after a few pictures the regions are totally wrong (bad size, position...but the names are still OK).
I can reproduce this with a lot of pictures, but I can't tell what trigger the bug: it can start on any picture, but it's not systematic.
Going back and forth between pictures can help to trigger the mess... Once it began, if I go back to the pictures that were correctly displayed, they are wrong too.
Seems that something should be reset between pictures but isn't?
If I browse the same set of pictures with other viewers (Digikam, GraphicConverter, Photo Supreme) everything is fine.
(I'm new to XnView and like it very much so far, thanks for the excellent work!)
Re: 0.99.1 Face tag regions displaying incorrectly [Mac]
is it possible to have the set of pictures?
Nicolas
Post by Nicolas »
xnview wrote: Fri Nov 12, 2021 7:09 am is it possible to have the set of pictures?
Sure, I sent you a PM (actually probably two, sorry, I was confused by the message staying in the send box...)
This problem is supposed to be fixed in XnView MP 0.99.4. Please check and confirm the bug fix here.
Nicolas
Post by Nicolas »
Fixed! And the new regions layout is way better :D
