Truncated fullscreen info
cicciobello
Post by cicciobello »
In fullscreen info, long lines is not wrapped and is truncated.
This releases (tested time ago) DON'T have this bug:
Version 0.96.2 64bits (May 5 2020)
Version 0.93.1 64bits (Mar 6 2019)
Version 0.95 64bits (Jan 15 2020)
Edit XMP (sidecar) and insert data in "Description"
Data must be longer (more of screen width)
For fullscreen info I use monospaced font and HTML ON
View image in fullscreen with info ON (obviously)
Actual behaviour: Long text line is truncated to screen width
Expected behaviour: Long text line wrap to second line (as in MP 0.96.2)
XnView MP 0.99.4
Win 10x64
Re: Truncated fullscreen info
and if HTML is OFF?
cicciobello
xnview wrote: Sun Dec 05, 2021 10:42 am and if HTML is OFF?
When HTML OFF long line is wrapped (and NOT truncated), then this is OK, but...
All HTML formats (color, etc) is gone! :-(
Without HTML, info text is no clearly readable.
Release 0.96.2 does not have this problem with HTML ON.
which text do you use?
cicciobello
xnview wrote: Mon Dec 06, 2021 3:19 pm which text do you use?
I use various texts, but this is one:
<font color="LightGreen">(({Annotation}))</font>
<font color="Grey" size="2">((Source: {IPTC:Source} ))(( by {IPTC:Caption Writer}))</font>
<font color="Grey">((Taken {EXIF:Date Taken [Y-m-d]} h {EXIF:Date Taken [H:M]})) ((- {EXIF:Exposure Time} s - f/{EXIF:F-Number} - {EXIF:Focal Length} mm ({EXIF:Focal Length 35mm} mm) - {EXIF:ISO Value} ISO))
((GPS: {EXIF:Latitude} {EXIF:Latitude Ref}; {EXIF:Longitude} {EXIF:Longitude Ref}))((; m {EXIF:Altitude} {EXIF:Altitude Ref}))</font>
((<b><font color="LightBlue">[{File Index}]</font></b> )){Filename With Ext} ({Zoom}%) <font color="Yellow">{Directory}</font>
{Width} x {Height} @ {DPI} SPI - (({Format} @ )){Bpp} BPP - {Size KB} KB ((- {EXIF:Colour space}))
<font color="LightGreen">(({EXIF:Make}: {EXIF:Model}))</font>
This problem is supposed to be fixed in XnView MP 0.99.7. Please check and confirm the bug fix here.
cicciobello
Fixed!
