Hello
I have this setting for the title bar
titleBarTemplate={Filename} Le {EXIF:Date Taken [Y-m-d ]} \xe0 {IPTC:Sublocation} Avec {IPTC:Keywords}
it displays as expected with XnView MP 97.1 (with windows 10 on jpg files)
But with XnView MP 99.6 only le token {Filename} is expanded the 3 others are left blank
that gives "Myimage.jpg Le à Avec"
I did not notice precisely the version when this appears but at least 3 or 4 before 99.6, could be a year old.
It is a very minor item but if it can help you to improve this superb XnView it is my pleasure.
titleBarTemplate does not display Exif or Iptc in 99.6
jlrjlr
Re: titleBarTemplate does not display Exif or Iptc in 99.6
it works here, so please send me a file that doesn't work..
This problem is supposed to be fixed in XnView MP 0.99.7. Please check and confirm the bug fix here.
