See attachments: screenshot and original file.
XnView MP Windows / Version 0.99.6 64bits (Dec 10 2021) / Libformat version 7.99
Regards,
Leency
[BUG] Bottom line of image is not shown
- Attachments
- Screenshot_1.png (8.79 KiB) Viewed 19171 times
- image with the issue
- 16x16_ncg.gif (1012 Bytes) Viewed 19171 times
Re: [BUG] Bottom line of image is not shown
Ah, sorry I forgot to mention:
Try to set system zoom to 125%.
Probably this is the reason.
125% can be a problem. what do you use in "Settings>View>High zoom quality"? If you zoom in & zoom out to go back to 100%, same display?
Default setting: Zoom out, spline 36.
Zoom in|out and restore doesn't help.
This problem is supposed to be fixed in XnView MP 0.99.7. Please check and confirm the bug fix here.
