0.99.7 Batch Rename: duplicate suffix is always uppercase
Transalpin
Post by Transalpin »
XnView: MP 0.99.7 64bit
OS: Windows 10 64bit
Hello!
When batch-renaming pictures, and selecting a character (letter, not number) as duplicate suffix, it's not possible to get it in lowercase. Of course, I checked Case: "Name and extension lowercase" (and also tried the other options), but the suffix always remains uppercase.
Screenshot:
You can see the problem e.g. at the new name "2022-01-02_15-22A.jpg".
Thanks for all the work!
Re: 0.99.7 Batch Rename: duplicate suffix is always uppercase
Transalpin
Downloaded 1.00 and tested: Bug has been fixed - thanks a lot! Great work.
(Found a little error in the new german translation and already messenged Helmut about it.)
burakyolcu
Post by burakyolcu »
hello,
first of all your program is really useful. Thank you very much for bringing such a program to us.
I was using another program to batch filename rename. It looks like you won't need it anymore thanks to your program. Sorting by EXIF ​​date and renaming is great. However, in batch file name change, the names of files in different formats start from 1. For example, if there are four files named a1.jpg
a2.mov
a4.mov
when I want to change their names to z, it changes
z_001.mov
z_002.mov.
This is annoying when chronological order is very important to me.
z_002.mov
z_004.mov
can we make it like this?I would be very grateful if you could fix this and it would be great.
Thank you.
