Standard Windows Ctrl+Page Up/Down shortcuts (to switch tabs) don't work in these dialogs:
- Batch Convert
- Properties
and possibly other dialogs too...
So, when I select script in Batch Convert dialog and I want to check it, I can't use a mouse, since current keys (Left/Right) don't work, I must use Tab key several times first.
Current keys (Left/Right) could be retained, but also these standard shortcuts, Ctrl+Page up/Down should be added, I think.
XnView 1.82 <x>
B1: Standard Win. Ctrl+Page Up/Down shortcuts don't work...
Dreamer
Dreamer
Re: Work here
I'm sorry, it's Ctrl+Page Up/Down shortcuts (to switch tabs), fixed in the first post.Clo wrote:Hello !
- I just tested PgeUp¦PgeDown in "Properties" >> “Exif” where is a long list : they work perfectly here…
KR
Works too
- Works too here, shows the corresponding item within a dashed frame… but there is no highlight background-colour, while there is one (the Win one configured for the selection) with simply PgeUp¦PgeDown
- Same behaviour with Ctrl+Home¦End —> Dashed frame around the first¦last line… like shown below :
Under Win XP-Pro
Re: B1: Standard Win. Ctrl+Page Up/Down shortcuts don't work
Yes, currently i have a problem to add these keys...Dreamer wrote:Standard Windows Ctrl+Page Up/Down shortcuts (to switch tabs) don't work in these dialogs:
- Batch Convert
- Properties
Dreamer
So postponed?xnview wrote:Yes, currently i have a problem to add these keys...
yesDreamer wrote:So postponed?xnview wrote:Yes, currently i have a problem to add these keys...
