Hide CRC from compare mode info area?
lphilpot
Post by lphilpot »
When image Information is shown while in Compare Mode (Shift+C), the image's CRC is prepended to whatever is configured in Settings | View | Info. Is there a way to hide / remove the CRC from this information?
Thanks.
Len Philpot
Re: Hide CRC from compare mode info area?
lphilpot
Post by lphilpot »
Thank you!
Len Philpot
lphilpot
Post by lphilpot »
I'm still seeing the "CRC from nowhere" in the new beta:
Thanks.
Len Philpot
Franky
Post by Franky »
Below, there is a checkbox to not see the CRC
lphilpot
Post by lphilpot »
Arghh... you are absolutely correct! I didn't see that.
Thanks...
Len Philpot
chrisncy
Post by chrisncy »
Que signifie ce CRC ? et à quoi cela sert il ?
Merci
Franky
Post by Franky »
Cela veut dire "Contrôle de redondance cyclique"(cyclic redundancy check).
C'est un code qui est générer en fonction des paramètres du fichier, ce qui permet de s'assurer qu'il n'y a pas d'erreur suite à une copie par exemple.
