Zoom selection bug.
FKCapitalism
Zoom selection bug.
Post by FKCapitalism »
Problem with drawing selection on image, that you only allowed to draw selection box on 25% upper right corner of image that is open in large view or full screen.
1. You have several images in a folder
2. Windows explorer image to open
3. double click mouse1 two times to go in thumbnails view
4. select next image in XnView thumbnail view and double click mouse3 to open large view
5. now selection only can be done in upper right corner about 25% of whole image size.
Only area of image where selection box can be drawn.
Re: Zoom selection bug.
i can't reproduce, do you use windows font scaling?
FKCapitalism
Forgot to mention this only happens with Sony ARW files, uploaded for your here.
xnview wrote: Mon Feb 14, 2022 9:52 am do you use windows font scaling?
No
i can't reproduce... when you open the ARW, do you see 1080x1616 in the status bar?
FKCapitalism
xnview wrote: Wed Feb 16, 2022 4:00 pm i can't reproduce... when you open the ARW, do you see 1080x1616 in the status bar?
1616x1080x48
Note when i make selection it also tell me that i have selected 1616 x 1080 however in reality its only small portion of image that is selected.
FKCapitalism
I noticed once i double click a ARW file in windows explorer it opens full screen and zoom worksokay, when i navigate next file in folder (using right arrow) it already has problem with zoom and if i go back to first file open (that was working good) zoom also stops working.
Files i uploaded first need to be extracted into folder to reproduce bug, if they open from archive they work for me as well.
if you open the ARW file from XnView's browser same problem?
FKCapitalism
xnview wrote: Mon Feb 21, 2022 8:42 am if you open the ARW file from XnView's browser same problem?
Same behavior if i open from within XnView interface, first full screen image zoom works okay, after i switch to next image zoom is broken.
FKCapitalism
xnview wrote: Mon Mar 28, 2022 10:17 am This problem is supposed to be fixed in XnView MP 1.00 beta. Please check and confirm the bug fix here.
Partially fixed, still having this bug:
If you open image from folder thumbnails view zoom works now, then close image and open another one from thumbnails view it still works.
If you open first image in folder and press keyboard right arrow to switch to second image zoom works, but if press right arrow again to switch to third image - zoom is broken again, if you press left arrow to go back to to second image zoom is broken.
Same thing if you open third image in folder and press left arrow to switch to second image zoom works, but if you press left arrow again to switch to first image - zoom is broken again, if you press right arrow to go back to second image zoom is broken.
FKCapitalism wrote: Mon Mar 28, 2022 7:47 pm If you open first image in folder and press keyboard right arrow to switch to second image zoom works, but if press right arrow again to switch to third image - zoom is broken again, if you press left arrow to go back to to second image zoom is broken.
I can't reproduce, do you use 'View>Misc>Read one ahead'?
FKCapitalism
xnview wrote: Mon Apr 11, 2022 7:40 am
I tested with all default settings.
1. Download this three files UNZIP in dedicated folder.
2. Download XnVewMP 1.00 beta 1 and unzip to another dedicated folder
3. When starting XnViewMP select location for *.ini and catalog inside XnView folder (not system).
4. Navigate to folder with three ARW images and double click first image.
5. Drag zoom rectangle to make sure it works on bottom portion of image (no need to press middle mouse button to zoom in)
6. Press keyboard right arrow to go to second image, repeat step 5 - should work okay.
7. Press keyboard right arrow to go to third image, repeat step 5 - zoom broken.
ok i can reproduce, will be fixed in beta 3
consultantcamel wrote: Mon Apr 18, 2022 11:22 am I have the same problem, I hope it will be fixed shortly
please check beta 3
