Slow speed to load folder in favourites
roverto007
Post by roverto007 »
I have a problem with the folders with many subfolders.
If I click in favourites shortcut is very slowly to load the folder. but If I press via folders tree is very fast
You can see in the youtube video link
https://youtu.be/2BeD3Ik7k20
I have the last versión updated
Can you help me?
Re: Slow speed to load folder in favourites
The video is not very clear, it's not a shared folder? You can reproduce with any favorite folder?
roverto007
To clear that. the root folder of that folders has about 6900 subfolders. And that's the problem, "with many subfolders" I have the problem but with few subfolders there is no problem
If I press in the "folders" panel is in less of 1 second to load the the files. but if I press the same folder but in favourites it take a few seconds
even if there are more folders in that folder. to enter in that folders take a few seconds too
roverto007
I saw another post with same problem but it said that the problem it's fixed for 0.99.4 version . I have Version 0.99.7 64bits (Jan 13 2022) and it has same bug
It's not only with favorites. If you select this pathname in paths list, i have same delay.
roverto007
Thanks it works¡¡¡¡
