PSB preview corrupt [Solved]
getho
Post by getho »
large psb files preview displays as garbage (corrupt)
Re: PSB preview corrupt
Thank you for your problem report, getho. Could you please provide a sample PSB file to reproduce the problem?
Ito
Post by Ito »
I have the same problem.
XnView MP MacOSX
Version 1.3.1 64bits (Oct 11 2022)
Libformat version 7.126
Ito
Post by Ito »
Actually not every one preview is corrupted
Can you provide a link for Pierre to download a PSB file that doesn't display correctly?
I assume that PSB files are too large to attach to a post, current file size limit is 2MiB, if not you will need to place the file in a ZIP or similar archive in order to be able to attach it.
Ito
Post by Ito »
could you send me one that works?
Ito
Post by Ito »
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
Ito
Post by Ito »
Hi ,
I downloaded latest version but at my side the problem is still stay.
PSB images are still corrupted
in preview or thumbnail?
Ito
Post by Ito »
In thumbnails, maybe i have to rebuild datebase but i do knot know from where :) :)
In preview is ok
yes you need to use View>Rebuild thumbnails
Ito
Post by Ito »
Most of the PSB files are fixed. :)
But there are still some stay corrupted
I am sending link for test
https://www.dropbox.com/s/rx7w26p96pjtt ... 3.psb?dl=0
