CTRL + S to save
Blackbeen
CTRL + S to save
Post by Blackbeen »
Is broken on the most recent update.
Re: CTRL + S to save
on all formats? same with File>Save?
Blackbeen
Post by Blackbeen »
Specifically saving screen grabs, option is greyed out.
a screenshot can't be saved, the original file doesn't exist, you need to use 'save as'
Blackbeen
Post by Blackbeen »
The file does indeed exist in xnview & I HAVE saved via CTRL + S prior to the last update.
If you attempt to close out of the grab in xnview you get prompted to save as default not save as.
Blackbeen wrote: Tue May 10, 2022 7:19 am The file does indeed exist in xnview & I HAVE saved via CTRL + S prior to the last update.
do you means XnView MP 1.0?
Blackbeen
Post by Blackbeen »
The version I have on my notebook than I didn't allow to update & works is .98.4 64 bit.
Please could you describe the bug more, i don't understand...
Blackbeen
Post by Blackbeen »
As I said CTRL + S to save does not work only with the extra shift key, CTRL + S does nothing.
Blackbeen wrote: Fri May 13, 2022 10:32 am As I said CTRL + S to save does not work only with the extra shift key, CTRL + S does nothing.
Are you able to you provide steps to reproduce?
And could the issue you are experiencing possibly be related to the fact that when the Print screen key is pressed, the screen image is placed on the clipboard, which then needs to be loaded in some way into XnView MP, and is an unsaved image until it is saved by a user action?
Blackbeen
Post by Blackbeen »
No, the copy to clipboard box is not ticked & the image is loaded in Xnview.
its only a problem with shortcut??
Blackbeen
Post by Blackbeen »
Yes, the key command.
Anibina
Post by Anibina »
This seems to be the problem.
Ctrl + s doesn't work because,
the File > Save menu option is grayed out (disabled) when:
- Creating a new image: File > New image...
- Capturing a screenshot in XnView MP: Tools > Capture...
- Or when pressing the keyboard key: PrintScreen
and in choosing: Edit > Import Clipboard
There is however a Save button that works.
When the image tab is closed, then a popup appears:
Save changed file
Do you want to save changes to "Clipboard 1"?
The popup has four buttons:
Save as..., Save, No, Cancel
The Save button is selected by default.
Pressing Enter or mouse clicking on the Save button.
Opens the Save As window.
Expected
The menu choice: File > Save shouldn't be disabled.
Choosing it or pressing Ctrl + s
Should open the Save As window,
just like it does when the Save button is pressed,
in the (close tab) Save changed file popup.
System
XnView MP Windows
Version 1.0 64bits (Apr 28 2022)
Blackbeen
Post by Blackbeen »
Anibina wrote: Fri May 13, 2022 12:16 pm The menu choice: File > Save shouldn't be disabled.
This is the crux of the problem, it does not, I don't use screen print key at all in favor of the capture key on the task bar, here are the options I have to capture, as stated Ctrl + s does nothing only attempting to close out of the grab displays the save/save as options.
