1.0: Setting "Always in fullscreen" option is not working properly
lffs
Post by lffs »
Subject: 1.0: (Settings: View->Info->Always in fullscreen) option does not work properly
XnView MP 1.0 - 64 bit
OS: Windows 10 21H2 64bit
After unchecking (Settings: View->Info->Always in fullscreen) and restarting XnView MP, "information" will be displayed by default in both windowed and fullscreen modes. You cannot set (Menu: View->Show information) to keep the default off in fullscreen.
Effect: (Menu: View->Show information) is displayed by default and needs to be turned off manually.
1. uncheck (Settings: View->Info->Always in fullscreen)
2. restart XnView MP
3. Open an image and view it in windowed and full-screen mode
4. Problem occurs: "Information" is displayed by default
Actual behaviour (bug): (Menu: View->Show information) is displayed by default and needs to be turned off manually.
Expected behaviour: When the checkbox is unchecked, "Information" is not displayed by default in both window and fullscreen mode.
Re: 1.0: Setting "Always in fullscreen" option is not working properly
This problem is supposed to be fixed in XnView MP 1.01. Please check and confirm the bug fix here.
lffs
Post by lffs »
xnview wrote: Tue Aug 16, 2022 10:16 am This problem is supposed to be fixed in XnView MP 1.01. Please check and confirm the bug fix here.
Confirmed, the issue is fixed in Version 1.01. Thank you!
