doesn't show animated gif correctly
Post by Guest »
If the image size is large, XnView doesn't show it correctly.
XnView 1.82 <x>
Re: doesn't show animated gif correctly
Anonymous wrote:If the image size is large, XnView doesn't show it correctly.
Could you post a sample?
Post by Guest »
http://i.cool.ne.jp/clspaste01/ToHeart2_omake.GIF
Optimize it !
:) Hello !
- The sample "as is" is 1.54 MB, and it doesn't work properly in XnView.
- I optimized it in Gif-MovieGear (an old version…), then the size is reduced to 1.26 MB and the animation works in an acceptable way…
- It seems that there is a threshold of size beyond which the animation can't be played properly.
:mrgreen: Kind regards,
Xyzzy
Post by Xyzzy »
b2
I confirm using provided sample- plain black in places where there should be a change.
The GIF plays OK in Opera.
X.
