v1.00 - Minor GUI issue with abort button
appyface
Post by appyface »
XnViewMP v1.00 64-bit portable on Win10.
Minor GUI issue. The abort button on the popup search box does not work. Clicking red X in upper right does.
1. Issue Ctrl-F from the browser to bring up search box
2. Click 'abort' button
Re: v1.00 - Minor GUI issue with abort button
Thank you for your problem report, appyface. From what I can see there is some misunderstanding: "Abort" means that search that is currently running is aborted/stopped. This works fine for me. If you want to both abort search and close the search dialog you have to use system menu "[X]".
But:
When aborting, in the log it says "Finished." which is not quite true - it should say "Aborted", "Stopped by user", or similar. :bug:
When starting next search, it says Finished: 8 file(s) found... from the previous search. I.e. this label is not reset when search is started. :bug:
appyface
Post by appyface »
OK fair enough, it operates a little different than I expected. My experience with OK and Cancel (or equivalent names - search and abort, for example) will exit a pop-up and no need to use the 'X'. If this deviates from that "standard" (if that's what you can call it) that's fine. Thanks for the reply.
This problem is supposed to be fixed in XnView MP 1.01. Please check and confirm the bug fix here.
