Persisted slideshows with files with equals signs in filenames not possible
hhh
Post by hhh »
Windows 10
XnView MP Windows
Version 1.0 64bits (Apr 28 2022)
  • Place two image files in a directory, where one has an equals sign (=) in its filename.
  • Open XnView MP to view the directory.
  • Use the menubar to open the slideshow dialog (translated from what I see to English: Create > Slideshow...).
  • Add both image files to the slideshow. After pressing OK to start the slideshow all images are shown.
  • Save the slideshow as an .sld file.
  • Open the .sld file in the slideshow dialog or double-click the .sld file to start the slideshow. Bug: The file with the equals sign isn't included in the file list or in the slideshow, respectively.
Re: Persisted slideshows with files with equals signs in filenames not possible
This problem is supposed to be fixed in XnView MP 1.02. Please check and confirm the bug fix here.
hhh
Post by hhh »
Thanks. It works now.
