1.01: Video preview in Browser window isn't zoomed to fit
m.Th.
Post by m.Th. »
Video preview in Browser window isn't zoomed to fit, so it shows only on a small part of the Preview pane, if this pane is big.
The same thing happens when we double-click on video file to open it in the Editor.
See the screenshot for the effect at
https://imgur.com/a/55jUZFo
(Off topic) I cannot attach images here because the board reachet the quota for this.
m. Th.
Re: 1.0.1: Video preview in Browser window isn't zoomed to fit
could you send me a video sample?
Chrispynutt
Post by Chrispynutt »
Hello I get the same with all formats and full screen/windowed, not just preview. I tested with videos from https://freetestdata.com/video-files/.
I use https://aur.archlinux.org/packages/xnviewmp on:
OS: Manjaro 21.3.7 Ruah
Kernel: x86_64 Linux 5.15.60-1-MANJARO
DE: KDE 5.96.0 / Plasma 5.24.6
WM: KWin
GPU: AMD Radeon RX 6700 XT (navy_flounder, LLVM 14.0.6, DRM 3.42, 5.15.60-1-MANJARO)
FFMPEG 5.0.1
Chrispynutt
Re: 1.01: Video preview in Browser window isn't zoomed to fit
Also the same problem when I try the Flatpack version.
m.Th.
Post by m.Th. »
xnview wrote: Mon Aug 22, 2022 11:46 am could you send me a video sample?
Any video. On the latest Win10 with default settings.
m. Th.
m.Th. wrote: Wed Aug 24, 2022 1:37 pm Any video. On the latest Win10 with default settings.
Strange, i'm not able to reproduce
Jean_59
Post by Jean_59 »
I have the same problem with MP1.01 and 1.02 and any videos both full screen and display in window.
The mouse cursor is not visible in full screen.
I turn back to MP1.0
Windows 10 famille, Nvidia GTX 960
Win 10-64, Intel i7, idsplay Dell U2413
Jean_59
Post by Jean_59 »
I added "useInternalVideoPlayer=false " in th file Xnview.ini / [General],
and MP1.02 works now perfectly !
K_Lite_Codec_Pack_Basic_v17.1.5 is installed.
see message by Xnview july 9-10, 2019
"Re: Not displaying WEBM, or MP4 properly on new Win10 installation"
I had done the modification at the time, but it had turned back to "true"
m.Th.
Post by m.Th. »
xnview wrote: Wed Aug 24, 2022 1:38 pm
Perhaps it has something to do with this?
https://www.xnview.com/mantisbt/view.php?id=2405
m. Th.
m.Th. wrote: Mon Aug 29, 2022 7:54 pm Perhaps it has something to do with this?
yes, but i'll try to reproduce...
This problem is supposed to be fixed in XnView MP 1.3.0. Please check and confirm the bug fix here.
