1.02: program constantly freezes/hangs when playing or switch video
fireattack
There is no reliable STR, but it happens so frequently that it's almost guaranteed to happen if you're trying to view a folder with batch of videos.
It mostly happens when you go Prev/Next file while one is playing back, both in browser (with preview) and viewer mode.
If you're in browser mode, it sometimes only freeze the preview thread, so you can just click somewhere else to recover. But if you're in viewer mode, the whole program will always freeze.
Re: 1.02: program constantly freezes/hangs when playing or switch video
on windows 10? which video format? Auto play is enabled?
fireattack
Windows 7. A mix of MP4/MKV formats, x264 encoding. Yes auto-play is on.
Edit: reproduced on my Win10 machine, too.
fireattack
Screen record to show the bug.
- Attachments
- xnview mp video freeze bug.mp4
- (1.82 MiB) Downloaded 261 times
is it possible to send you a test version?
fireattack
Sure, feel free to send me that. You can PM me if you prefer.
This problem is supposed to be fixed in XnView MP 1.3.0. Please check and confirm the bug fix here.
It looks like nothing has changed, I downloaded version 1.3 x64 today and I get the same problem with the program freezing when clicking on a video.xnview wrote: Tue Sep 06, 2022 12:44 pm This problem is supposed to be fixed in XnView MP 1.3.0. Please check and confirm the bug fix here.
viewtopic.php?p=179926#p179926
no image? do you know the version of installed OpenGL?MARK2580 wrote: Fri Sep 09, 2022 2:51 am It looks like nothing has changed, I downloaded version 1.3 x64 today and I get the same problem with the program freezing when clicking on a video.
everything happens exactly the same as in the video, nothing has changed with the new versionxnview wrote: Fri Sep 09, 2022 7:22 amno image? do you know the version of installed OpenGL?MARK2580 wrote: Fri Sep 09, 2022 2:51 am It looks like nothing has changed, I downloaded version 1.3 x64 today and I get the same problem with the program freezing when clicking on a video.
Regarding OpenGL, I have no idea where to look at the version. I went to AIDA64 there in the OpenGL section there are ticks for all versions from 1.1 to 4.6
i send you a PMMARK2580 wrote: Sun Sep 11, 2022 4:40 ameverything happens exactly the same as in the video, nothing has changed with the new versionxnview wrote: Fri Sep 09, 2022 7:22 amno image? do you know the version of installed OpenGL?MARK2580 wrote: Fri Sep 09, 2022 2:51 am It looks like nothing has changed, I downloaded version 1.3 x64 today and I get the same problem with the program freezing when clicking on a video.
Regarding OpenGL, I have no idea where to look at the version. I went to AIDA64 there in the OpenGL section there are ticks for all versions from 1.1 to 4.6![]()
I hope these dlls will be supplied with the program in the future? (yes it works now)xnview wrote: Mon Sep 12, 2022 6:27 ami send you a PMMARK2580 wrote: Sun Sep 11, 2022 4:40 ameverything happens exactly the same as in the video, nothing has changed with the new version
yesMARK2580 wrote: Mon Sep 12, 2022 3:10 pm I hope these dlls will be supplied with the program in the future? (yes it works now)
