Rating/mark be shifted after renaming
alee001
Post by alee001 »
Rating/mark be shifted after renaming or missing of name, which mark cannot be following in picture. :?
Re: Rating/mark be shifted after renaming
could you describe the way to reproduce
alee001
Post by alee001 »
For example folder pictures from pic000.jpg to pic998.jpg, I rate/mark for pic005.jpg then rename all pictures from pic001.jpg to pic999.jpg, rating/mark still keep the old name as pic005.jpg and not corrected to pic006.jpg?
please post some screenshots
alee001
Post by alee001 »
Often occurs with a large number of images (about a thousand or more)
alee001
Post by alee001 »
Another situation is that after the png files are marked/rating and then batch converted to jpg files, all the markings/rating will disappear.
alee001 wrote: Wed Oct 05, 2022 3:12 am Often occurs with a large number of images (about a thousand or more)
on 1.3.1?
alee001
Post by alee001 »
Yes, Version 1.3.1 64bits (Oct 11 2022)
alee001 wrote: Sun Nov 06, 2022 6:34 am Yes, Version 1.3.1 64bits (Oct 11 2022)
how do you reproduce? what do you have in settings>Metadata?
alee001
Post by alee001 »
Metadate> In IPTC&XMP sheet select items as following:
and could you describe a way to reproduce?
alee001
Post by alee001 »
As like following sample:
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
alee001
Post by alee001 »
xnview wrote: Tue Dec 13, 2022 7:39 am This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
I need more time test, if have bug will report you.
