Windows 1.3, Jpeg Lossless Rotation Not Working
phototraveler7
Post by phototraveler7 »
Using XNView Mp 1.3.0 on Windows, none of the lossless jpeg rotation options are working. Here's a video:
https://jiij.cc/snaps/2022-09-25_09.06.39.mp4
As you can see, I tried:
*Rotate counter clockwise
*Rotate clockwise
*Rotate based on EXIF orientation field
*Reset EXIF orientation field
None of these options do anything.
If I try all the same options on the same jpeg file with XnView Mp on Linux, they do rotate the file as expected.
Re: Windows 1.3, Jpeg Lossless Rotation Not Working
is it working in browser? could you send the file?
phototraveler7
Nope - the behavior is the same whether I rotate it in "view mode" or "browser mode" (assuming that's what u meant)
The behavior is the same with every jpeg I've tried, but sure, where should I send it?
I've tried and no problem. you can post it here. Which settings>Browser>Misc?
phototraveler7
https://www.dropbox.com/s/ksai1lra62b1g ... 9.jpg?dl=0
Both checked: https://jiij.cc/snaps/2022-09-26_09.07.18.png
phototraveler7
I also tried deleting the xnview.ini file to start fresh with a brand new config, & the behavior is the same
metal450 wrote: Tue Sep 27, 2022 5:33 am I also tried deleting the xnview.ini file to start fresh with a brand new config, & the behavior is the same
I don't understand, with a fresh install, i can't reproduce withyour picture file. 'Change EXIF field' ON or OFF
phototraveler7
I figured out when it happens: it only occurs when the file is under a "long" path. If I move the same file it to a shorter path, it works. However, everything else seems to be functional under the long path: I can view the file, hit F2 to rename it (to a longer or shorter name), etc - from within xnViewMp. Just when I try to rotate, if it's in a long path, it behaves as shown.
how many characters do you have in your pathname?
phototraveler7
It looks like the point where it starts happening is when path+filename > 250 (not including extension ".jpg"). At 250 it works, at 251 it stops working.
However, I'd note that other image editors do seem to be able to write changes to longer paths without issue - i.e. if I open it in GIMP & do the rotation, then export it to the same path+filename, it works. So it seems to be unique to XnView
on your system, HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem\LongPathsEnabled is set to 1?
phototraveler7
It was previously set to 0, but I set it to 1, rebooted, & the behavior is the same.
Maybe is XnView not marked as "long path aware" in its manifest (
<ws2:longPathAware>true</ws2:longPathAware>
), *or* it using non long path-aware functions (https://learn.microsoft.com/en-us/windo ... s=registry)?
metal450 wrote: Sat Oct 01, 2022 3:57 pm Maybe is XnView not marked as "long path aware" in its manifest (
No, the bug was only in lossless rotation, XnView supports long filename already...
phototraveler7
Great!
