no drop shadow effect in Batch convert?
tinguaro
Post by tinguaro »
first to say, I´m very satisfied to have XnV installed on my PC.
It helps a lot to manage my Photos.
I´m getting more and more used to work with XnV and it´s my "Swiss Knife" now.
Thanks to Pierre.
But:
I can´t find "drop shadow" effect in Batch convert (advanced options).
Not there or am I blind?
Any other way to include "drop shadow" in batch mode?
This would be be very helpfull to prepare pics for a web gallery (or other tasks).
Thanks in advance.
ckv
Post by ckv »
Not there I am afraid. I am sure that somewhere was a topic about this, but I didn't manage to find it. I also checked the 1.82 beta and even that don't have it in the Batch convert. :( Probably there are a reason for this.
Re: no drop shadow effect in Batch convert?
tinguaro wrote:Hi,
Thanks to Pierre.
But:
Thanks in advance.
Ok, i'll add it
tinguaro
Post by tinguaro »
@ckv - Thank you for quick answer- Well, this obviously is a missing feature.
@pierre - Perfect! Very quick response! Thank you!. Waiting for next release then.
bob3150
Post by bob3150 »
Yes, that is also for me a really important feature, hopefulle you can integrate it soon :)
Post by Guest »
Not in XnView 1.82 unfortunately ==> http://newsgroup.xnview.com/viewtopic.php?t=4695
tinguaro
Post by tinguaro »
Still not realized in 1.82.3. Still waiting (with patience).
Will we see it in on of the next versions?
