1.3.1 archive files in detail mode
qrti
Post by qrti »
A bug fixed in V1.3 is back again: Files from archive can't be opened in detail mode
https://www.xnview.com/mantisbt/view.php?id=2420
Re: 1.3.1 archive files in detail mode
you can't open an image file in archive?? Preview works?
qrti
Post by qrti »
- if I double click an archive the screen shows for the blink of an eye empty placeholder tiles of the archives content, then the screen gets empty
- in the empty screen if I select the filter 'custom' (it is already selected at this time) or if I select 'images', the empty placeholder tiles show up
- if I double click a tile nothing happens, no picture is shown as expected
in other mode, it works? which format in archive?
qrti
Post by qrti »
it does not work in any mode, the archive format is a normal zip
as I said in my first post, same error as documented here
qrti wrote: Sun Oct 23, 2022 9:20 am it does not work in any mode, the archive format is a normal zip
Strange, on windows?
qrti
Post by qrti »
yes, windows 11 22H2
could you send me the zip file?
qrti
Post by qrti »
it concerns any zip file ...
qrti
Post by qrti »
meanwhile I deleted the configuration ini and made a fresh installation, same behavior as before,
but I found a way to show the empty placeholders for zip files without changing filter options,
I added jpg to settings/browser/file list/custom filter/include, now the empty placeholders are displayed, but nothing happens after double clicking on them
qrti wrote: Mon Oct 24, 2022 6:33 am it concerns any zip file ...
It works with ZIP, so please send me a sample file?
qrti
Post by qrti »
attached an arbitrary zip file ...
Origami.zip
i don't understand, no problem with 1.3.1
qrti
Post by qrti »
I installed on three windows PCs with win11 and a virtual machine with win10 - same effect everywhere no preview of images in zip files and no opening after double clicking them. Sorry I can only report what I experienced.
I went back to version 1.3 no problems there.
As a workaround, if you move the xnview mp folder on destop (for example), it works
