1.3.1 - BUG - settings - browser - title bar
XnView: MP 1.3.1 64bits
OS: Windows 64bit (21H1), display resolution 3840x2160, win scaling 150%
Title bar's settings and behaviour
2. press F12 to open Settings
3. goto Browser -> Browser tab -> Title bar
4. set {Directory} and save settings
Actual behaviour:
1) Title bar in Settings is empty by default
2) When changed to {Directory}, Browser's address changes forward slash (/) to backslash (\)
Expected behaviour:
1) Title bar shall have {Directory} set by default
2) Local address shall be with backslash and not forward slash
Related suggestions:
1.3.1 - settings - browser - rework browser tab
Re: 1.3.1 - BUG - settings - browser - title bar
user0 wrote: Sat Oct 15, 2022 2:17 pm 1) Title bar shall have {Directory} set by default
No, by default there is no change in title bar when a file is selected
xnview wrote: Mon Oct 17, 2022 11:02 am
Let me rephrase and illustrate my point for better understanding:
There are no such issue with Viewer's title bar as it has correct keyword in corresponding section of Settings.
So I guess for the sake of consistancy - Browser's title bar setting shall have keyword as well.
yes it's normal. If title bar settings is empty, the title bar always shows pathname. If title bar settings is used, when a file is selected, title bar use this template
Ah, ok, finally got it )
There are 2 states of the Title bar in Browser mode:
- with file selected - can be changed via Settings
- without file selected - cannot be changed, always show current path
Well, it would help to have some context hint in that case or add some text, like this:
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
this issue can be considered closed
