XnView: MP 1.3.1 64bits
OS: Windows 64bit (21H1), display resolution 3840x2160, win scaling 150%
Viewer mode, Image menu
'Extract channel' has 'Alpha' option always enabled
2. open image with out alpha channel
3. check Image -> Extract channel -> Alpha option
Actual behaviour:
Expected behaviour:
'Alpha' option should be disabled if image has no alpha channel
1.3.1 - BUG - viewer - 'extract alpha channel' always enabled
- Attachments
- extract_channel_alpha.png (19.72 KiB) Viewed 1183 times
Re: 1.3.1 - BUG - viewer - 'extract alpha channel' always enabled
fixed in 1.4.0b1
This problem is supposed to be fixed in XnView MP 1.4.0. Please check and confirm the bug fix here.
fixed in 1.4.0b1, no regression in 1.4.0
